Go Back   Cincy Street Scene > Automotive > Car Specific Forums > Chevy Discussion
Old 08-10-2009, 05:17 PM   #41
Squale iii
FASTEST NA Vert
Squale iii is infamous around these partsSquale iii is infamous around these partsSquale iii is infamous around these partsSquale iii is infamous around these partsSquale iii is infamous around these parts
Do you have an underdrive pulley? My only idling issue was after the tune occasionally when I was stopped and I'd turn the wheel all the way one direction it would load up the powersteering or something and cause it to stall. Since installing the underdrive pulley it hasn't stalled once.
Anything LSX...GO 2:
www.ts-performance.com/
www.cincyspeed.com
xboxlive gamertag: I Fire People
ADD ME LETS MAKE A MW2 GROUP AND HAVE SOME FUN!
Squale iii is online now   Reply With Quote
Old 08-10-2009, 05:18 PM   #42
Squale iii
FASTEST NA Vert
Originally Posted by NastyZ28 View Post
Tracey Scott is doin the tuning. he's the only one who has touched my car. we've tuned it 3 different times, it got better at first, then seemed to just go back to wanting to die at idle and it falls on its face at a low RPM WOT
It's a top end cam, you prolly lose alittle down low with it. Mine will do that too if I'm at 900-1000 rpms and I go WOT. Solution= downshift LOL.
Old 08-10-2009, 07:10 PM   #43
BES_Stroked_Nova
LSx>you
BES_Stroked_Nova's Avatar
BES_Stroked_Nova is a jewel in the roughBES_Stroked_Nova is a jewel in the roughBES_Stroked_Nova is a jewel in the roughBES_Stroked_Nova is a jewel in the roughBES_Stroked_Nova is a jewel in the roughBES_Stroked_Nova is a jewel in the roughBES_Stroked_Nova is a jewel in the roughBES_Stroked_Nova is a jewel in the rough
ohhhh and Looking at the tune that came in my car when I bought it, for some odd reason when you would hit the rev limiter, it would shut off the spark and the fuel pump. When I switched cams to a MS4, it would hit the rev limit really easy, but every time I did hit the limit I would let off. but the fuel pump and spark had a re enable setting, which was set to like 4500 for some reason... anyways you know what I mean Kevin. and we didn't catch it till this year. thats why my pump would shut off and show really lean..
F&ck Chuck
LBZ Duramax, MBRP, EFI 5 way, Kolb Tuned
Just another Camaro SS
BES Racing Engine, Kolb Tuned
BES_Stroked_Nova is offline   Reply With Quote
Old 08-10-2009, 07:25 PM   #44
NastyZ28
NastyZ28's Avatar
NastyZ28 is infamous around these parts
yea i lost a bit down low. but once i hit about 3600 RPM's it takes off. but yea i got a ASP underdrive pulley...but Tracey called me earlier today, i'm goin to Cincy Speed to get the transmission and everything taken care of..
NastyZ28 is offline   Reply With Quote
Old 08-10-2009, 07:26 PM   #45
Kevin Doe
Kevin Doe's Avatar
Kevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to allKevin Doe is a name known to all
Send a message via AIM to Kevin Doe
Are you referring to B3303 Fuel Cut-Off Limiters in gear?
There are two columns, in-gear cutoff fuel, and in-gear reEnable fuel. The first column is when the fuel is cut, the second is what the rpms need to drop to before fuel is reintroduced. I have mine set to 7000 for cutoff, and 6999 for reEnable. The more seperation between these two the longer the limiter seems to cut out the power for.
These cut fuel via injectors, NOT fuel pump trigger. Unless you're talking about something different.
Your neighborhood 9sec Turbo Buick Killer.
Kevin Doe is offline   Reply With Quote
Old 08-10-2009, 08:10 PM   #46
whitedime
CincyLSxScene
whitedime's Avatar
whitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to beholdwhitedime is a splendid one to behold
Send a message via AIM to whitedime
My cam's not camming
whitedime is offline   Reply With Quote
Old 08-10-2009, 09:49 PM   #47
Squale iii
FASTEST NA Vert
I love my G5X3.... I bet you got sick top end, but I love having more power early on. I'm not sure why yours is stalling tho.
Old 08-10-2009, 10:37 PM   #48
1sicws6
JDM bum
1sicws6's Avatar
1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold
Send a message via AIM to 1sicws6
LOL Kent.
I need a big bumpstick.
If it ain't broke, I can't afford it....
1sicws6 is offline   Reply With Quote
Old 08-10-2009, 10:41 PM   #49
dsmawd350
13 second club
dsmawd350's Avatar
dsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of lightdsmawd350 is a glorious beacon of light
Send a message via AIM to dsmawd350
so the rumor about chinese people having small bumpsticks is true?
I would buy a ls1 but we all cant be fast.....
'93 T/A 355, Lt4 hotcam, LT's, CAI
Originally Posted by 1sicws6 View Post
LTx > LSx
Originally Posted by jfisher View Post
LTx > LSx > SBF
dsmawd350 is offline   Reply With Quote
Old 08-10-2009, 10:54 PM   #50
tator
giggity giggity
tator's Avatar
tator has a spectacular aura abouttator has a spectacular aura abouttator has a spectacular aura abouttator has a spectacular aura abouttator has a spectacular aura abouttator has a spectacular aura abouttator has a spectacular aura about
Send a message via AIM to tator
no build in progress, and no car in the garage.
Pair of trucks for dailys
tator is online now   Reply With Quote
Old 08-11-2009, 12:09 AM   #51
blacksi
blacksi is an unknown quantity at this point
I played with mine and got it pretty good. This was on 42lb injs, if you want a copy of the tune pm me your email, I am pretty sure I can still find it.
I didn't have to drill out the TB either.
Here's a clip I made of mine when I sold it.
http://videos.streetfire.net/video/T...-fd_140552.htm
blacksi is offline   Reply With Quote
Old 08-11-2009, 04:43 AM   #52
sohcthunder
Asshole By Nature(ABN)
sohcthunder's Avatar
sohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nicesohcthunder is just really nice
Send a message via AIM to sohcthunder
That thing, is fucking sick. Lol
Ricer-Bandwagon Member #003
sohcthunder is offline   Reply With Quote
Old 08-11-2009, 08:39 AM   #53
NastyZ28
NastyZ28's Avatar
not sure. Tracey said he'll take care of it. im not worried. i'm probably gonna do a nice set of heads soon so i can gain more power down low...but yea the top end is pretty sick
Old 08-11-2009, 11:53 AM   #54
Squale iii
FASTEST NA Vert
Baller right here lol.
Old 08-11-2009, 05:43 PM   #55
Cincyse_ryan
Your Welding Specialist
Cincyse_ryan's Avatar
Cincyse_ryan has a spectacular aura aboutCincyse_ryan has a spectacular aura aboutCincyse_ryan has a spectacular aura aboutCincyse_ryan has a spectacular aura aboutCincyse_ryan has a spectacular aura aboutCincyse_ryan has a spectacular aura about
Send a message via AIM to Cincyse_ryan
how much is tracey chargin for BJ's?
j/w...
09' Pearl White 370Z
92' 240sx-SR+3071r
95' Grand Cherokee
03' Spec-V- Sold!
07' Zx-6r
Cincyse_ryan is offline   Reply With Quote
Old 08-11-2009, 06:38 PM   #56
1sicws6
JDM bum
1sicws6's Avatar
Maybe he can adjust your CAS.
I kid I kid Ryan.
Old 08-12-2009, 12:43 AM   #57
Cincyse_ryan
im down to run again when youre ready... jc on if i fixed the issue.
Old 08-12-2009, 03:34 AM   #58
1sicws6
JDM bum
1sicws6's Avatar
I'm never driving the transcoon ever again. I'm scared.
Old 08-12-2009, 01:18 PM   #59
bestracing will become famous soon enoughbestracing will become famous soon enoughbestracing will become famous soon enough
+ Rep
"I wish my grass was EMO, Then it would cut itself"
www.nkyfba.com The place to be for Camaro and Firebird owners
Cincy Speed For all of your speed needs!
Old 08-12-2009, 05:02 PM   #60
1sicws6
JDM bum
1sicws6's Avatar
fml.
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
